Voltage level of SDO pin
Category: Datasheet/Specs
Product Number: LTC2484IDD, LTC2484
LTC2484's datasheet electrical characteristics tells VOH of SDO pin can be as low as VCC-0.5V tested at 800uA loading.
In my application, I am powering LTC2484 with VCC=5.4V & observed that the SDO pin voltage is 4.95V. The SDO pin loads are a pull down resistor of 100k & a buffer IC. The total load amounts to ~55uA.
As the load is lesser I was expecting a higher VOH for SDO pin. Please can you comment if this expected behavior of the IC.
Edit Notes
Question on VOH of SDO pin
[edited by: Krn at 2:58 AM (GMT -4) on 22 Oct 2024]
