AD5940 Temperature Example
The user encountered nonsensical temperature readings from the AD5940 when using the AD5940 temperature example. The issue was resolved by modifying the sequence to power on and off the temperature sensor and ADC, as per the ADuCM350 hardware reference manual, resulting in reasonable temperature values that respond to changes in the IC's temperature.
Product Number: AD5940
I'm having trouble with the AD5940 temperature example. No results were printed until I powered the SINC2NOTCH block by modifying this line
AD5940_AFECtrlS(AFECTRL_TEMPCNV|AFECTRL_ADCCNV|AFECTRL_SINC2NOTCH, bTRUE); /* Start ADC convert */
The code now prints four nonsensical results and stops:
Hello AD5940-Build Time:13:08:26
Internal calibration register value:
Gain: 0x00004000
Offset: 0x00000000
Result[0] = -14, -274.30(C)
Result[1] = 10178, 561.45(C)
Result[2] = 11926, 704.79(C)
Result[3] = 12369, 741.12(C)
How do I resolve this?
Parents
  • After looking at page 399 of the ADuCM350 hardware reference manual
    https://www.analog.com/media/en/technical-documentation/user-guides/aducm350_ug-587.pdf
    I modified the sequence so that the temperature sensor was powered on and off along with the ADC.
      //generate sequence to measure temperature sensor output
      AD5940_SEQGenInit(buff, BUFF_SIZE); //init sequence generator
      AD5940_SEQGenCtrl(bTRUE); //from now on, record all register operations rather than write them to AD5940 through SPI.
      AD5940_SEQGpioCtrlS(AGPIO_Pin1);  //pull high AGPIO1 so we know the sequencer is running by observing pin status with oscilloscope etc.
      AD5940_SEQGenInsert(SEQ_WAIT(16*200));  /* Time for reference settling(if ad5940 is just wake up from hibernate mode) */
      AD5940_AFECtrlS(AFECTRL_ADCPWR|AFECTRL_TEMPSPWR, bTRUE); /* Turn ON ADC and temperature sensor power */
      AD5940_SEQGenInsert(SEQ_WAIT(16*50));   /* wait another 50us for ADC to settle. */
      AD5940_AFECtrlS(AFECTRL_TEMPCNV|AFECTRL_ADCCNV|AFECTRL_SINC2NOTCH, bTRUE);  /* Start temperature and ADC convert */
      AD5940_SEQGenInsert(SEQ_WAIT(WaitClks));
      AD5940_AFECtrlS(AFECTRL_TEMPCNV|AFECTRL_ADCCNV|AFECTRL_SINC2NOTCH, bFALSE);    /* Stop ADC convert, hw ref manual p. 53 says TEMOCNV resets to 0 after conversion */
      AD5940_AFECtrlS(AFECTRL_ADCPWR|AFECTRL_TEMPSPWR, bFALSE); /* Turn off ADC and temperature sensor power */
      AD5940_SEQGenInsert(SEQ_WAIT(20));			/* Add some delay before put AD5940 to hibernate, needs some clock to move data to FIFO. */
      AD5940_SEQGpioCtrlS(0);     /* pull low AGPIO so we know end of sequence.*/
      AD5940_EnterSleepS();/* Goto hibernate */
      AD5940_SEQGenCtrl(bFALSE);  /* stop sequence generator */
      if(AD5940_SEQGenFetchSeq(&pSeqCmd, &seq_len) != AD5940ERR_OK){
    I'm now getting reasonable values
    Gain: 0x00004000
    Offset: 0x00000000
    Result[0] = 3622, 23.86(C)
    Result[1] = 3622, 23.86(C)
    Result[2] = 3623, 23.94(C)
    Result[3] = 3622, 23.86(C)
    These increase and decrease as I warm and cool the IC
Reply
    Gain: 0x00004000
    Offset: 0x00000000
Children
