I cannot get the RAM zero pressure offset override function to work on the MAX40109 EV kit. I have followed the Sensor Offset Calibration sequence detailed on page 53 of the Datasheet (19-101790,Rev2). The following are settings applied to the MAX40109 EVKit GUI (v1.0.97):
GUI settings recorded below:
Notable settings applied:
- Pressure Cal: Bypassed (Raw Mode)
- Trim Resistor: Connected
- Current Source: Connected
- PGA Mode: Bypass Mode
- RAM Override Value: 32767
- ZPO Override: RAM Override
No matter what my value on RAM Override value (0, 20, 100, 1000, 16383, 32767), it never changes the result. None of the above settings, with the exception of "PGA Mode:Bypass Mode" and "Pressure Cal: Bypassed Mode", seem to make any difference to the result. I have also tried setting the Bridge Drive mode to current mode (as opposed to voltage mode), and haven't been able to make any offset changes.
Can you please assist me with this - where I am going wrong?
Chris
