AD7705
Product Number: AD7705 Variation in the H time of DYDR, AD7705
Hello
The AD7705 is operated with the settings CLKIN=1MHz, CLKDIV=0 Data rate 20Hz.
The channel is switched under the above conditions to read out the data.
The measurement results show that there is a bias in the H time of DYDR.
However, I am only switching the channel, so I do not understand the reason for this bias.
The yellow on the graph is DYDR and the green is CS.
Thank you.
  • Hello  ,
    /DRDY hold time can vary when no data read has taken place between output updates. You can notice that there was an available data, which is unused, between /CS pulses. By the way, the /CS pin should be held low for the whole read/write operation.
    If a data was not read, /DRDY will be held high for 500 clock cycles.
    Yugel
