Is it possible that LTC2991 is driving current through the input pins configured for measuring voltage?
Product Number: LTC2991
I have encountered a strange failure on one of our boards. It has an LTC2991 monitoring 8 different voltages. One of the voltages is 1.8V and it is generated by an LT8614 switching regulator. This output of the regulator is connected directly to the input V3 of the LTC2991. So, what was found on this board is that this voltage becomes approximately 2.6V when the LTC2991 is installed on the board and goes back to normal when the IC is removed. All other input voltages of the LTC2991 are normal and way below allowed maximum. It is powered by 5V. There are no shorts on the board. Note that the same design works fine on dozens of boards in the field. I tried replacing the chip several times to no avail. Last time I did it I used another part from the same board, which was known to work. I exercised the switching regulator (with the LTC2991 removed) with an electronic load making sure that it is stable. As a last resort I decreased the values of the voltage setting divider on LT8614 from 100k and 86.6K to approximately 10 times smaller values to override any external current into its feedback loop that might be there and that worked! Now I am really confused. Is there a logical explanation for what I see? Is there a problem in my design or am I dealing with a faulty part or a bad batch of parts? Which one? LTC2991 or LT8614?
Thanks.
