AD7091 return wrong value
Product Number: AD7091
Hi.
I apologize in advance for the bad english.
I'm developing with AD7091.
My problem is ADC gives wrong value.
And If I get data more often, peak points appears.
VDD is 5V.
When input voltage is 500mV, expected value is around 0x19A(410). But I get around 0x334(820).
And input voltage is 1V, expected value is around 0x334(820). But I get around 0x668(1640).
Working like 2.5V input range.
Also, there is one more problem.
If I get data more faster, peak point appears.
2 kHz data acquisition rate with around 500mV input.
10 kHz data acquisition rate with around 500mV input.
Here's logic analyzer capture (10kHz acquisition, input voltage around 500mV)
I did software reset before main loop.
I have no clue about this.
  • Hi,  .
    I think you are getting the correct values. You have stated that when 500 mV is the input, you are getting a decimal value of 820, right? But that is how it should be. AD7091 uses a straight binary conversion. I am assuming you are using its internal reference, 2.5V, right? Then, this is how it was calculated.
    [Vin/Vref] x [2^N]
    [500 mV/ Vref] x [2^12] = 819.2 or 820.
    On the other hand, on your scope shot, it seems that SCLK lacks 4 pulses. I am seeing 12 SCLK pulses. It should be 16 SCLK cycle.  Are you using a custom eval board and controller board? If yes, would you mind sharing your schematic and the flow of your code from your bin file?
    Jo
  • Hi.
    I'm using AD7091(exactly, AD7091BCPZ) not AD7091R.
    Following the datasheet, reference is provided by VDD. (https://www.analog.com/media/en/technical-documentation/data-sheets/AD7091.PDF) So I thought ref is 5V.
    I just followed because it was explained using 12 SCLK in the datasheet. I'll try with 16 SCLK.
    Schematic I use is same with typical connection diagram in datasheet. (Not using pull-up resistor on SDO)
  • Hi,  .
    Apologies for missing some details from your thread. You are actually right with its VDD as its VREF (5V) and timing diagram for having 12 SCLK pulses. I was looking at the AD7091R-x family instead of AD7091. Let me correct this one for you. I'll get back to you in a while.
    Jo
  • Hi,  .
    Can you iterate here how did you implement the software reset on the device? Also, may I know how long the CNVST and Conversion time is? Can you try probing on VDD and check what is the voltage across it? Let me know other details so I can further help you.
    Jo
  • This is my reset code.
    CONVST low time is 600ns. And after 1us, CS goes low.
    I checked VDD with oscilloscope. It's about 5.02v
  • Hi,  .
    VDD seems fine. CNVST low time also satisfies the condition of being pulled up before EOC. Can you share your schematic? What is your signal source?
    On the other hand, I noticed on your timing diagram that you are using Mode 0 (CPOL=CPHA=0). Please ensure that your timing satisfies the condition of t12, the delay from the end of a conversion until the CS falling edge delay. And t10, the delay from CS falling edge until SDO exits the three-state condition. Lastly, the data is available from t2, data access time after SCLK falling edge.
    Warm regards,
    Jo
