KCC Quizzes AQQ303 about the radius of a circle
1. Quote of the month: "When I die, I want to die like my grandfather who died peacefully in his sleep. Not screaming like all the passengers in his car" - Will Rogers
2. Quiz AQQ304 about finding the radius of a circle
Good luck, and try to be
August Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Important: Read the blog first . The quiz questions are all based on the content of the blog:
Stay in the loop and win! Read the blog Current Output Driving Industrial Loops , then take our quick five-question quiz for a chance to win a gift card
AD4115
Recommended for New Designs
The AD4115 is a low power, low noise, 24-bit, sigma-delta (Σ-Δ) analog-to-digital converter (ADC) that integrates an analog front end (AFE) for eight...
Datasheet
AD4115 on Analog.com
AD4116
The AD4116 is a low power, low noise, 24-bit, Σ-Δ analog-to-digital converter (ADC) that integrates an analog front end (AFE) for six fully differential...
Datasheet
AD4116 on Analog.com
There is a pull up resistor connected to the DOUT/RDY pin in AD4115 evaluation board. What is the purpose of this pull up resistor? Also is pull resistor needed for error pin while interfacing with microcontroller?
I will contact the product owner and get back to you.
Janine
Hi Abbijeet ,
When /CS pin is high, the DOUT/RDY pin is in a tri-state mode. Having the pull-up resistor will set the digital input pin of the isolator to a known voltage instead of just floating. For the ERROR pin, if they are being used as inputs then the pin should be driven to either AVDD1 or AVSS. On the other hand, when used as an output, it does not need a pull up/down as the ADC will drive it high or low as appropriate.
JC
