We are testing the AD574 in standalone mode, bipolar mode (-10V to +10V analog input) and we are applying a 10V DC signal to pin 14. For the R/C' signal, we are applying a pulse that is at 3.3V for 9.9 seconds, and then goes low for 0.1 seconds, over and over. We are connecting various DB0-DB11 pins to a variable resistance box, which then connects to ground. We are measuring voltage across the resistance box, and it is never going above around 19 mV, and that's when we crank the resistance box up to 1 MV. Do you know why we are not seeing higher voltage on the outputs? Our goal is to measure a logic 1 voltage on the output pins, but for some reason we can't get any of the digital outputs to logic 1.
