I am mainly looking for an single-ended ADC with 4 channels and min 500 kbps sampling rate for each channel I want to achieve. This ADC will work with a micrcontroller that has I2C (max 400 kHz) and SPI (8MHz or max 32 MHz).
Do you have any product suggestions to achieve this purpose?
I really appreciate any feedback
Thank you in advance
Hi, FDagsever .
Here are some products I recommend to you. These products are 4-channels SPI interface with resolutions ranging from 12-bits to 20-bits with at least 500 kSPS sampling rate.
For I2C interface, you can try checking AD7091R-5 Datasheet and Product Info | Analog Devices.
May I know what is your specific application? On the other hand, you can still explore products fit to your application using the link below:
Selection Table for Precision A/D Converters | Parametric Search | Analog Devices
Jo
Hi, FDagsever .
Jo
Dear Jo,
Thanks very much for your reply. Only the first suggestion seems like suitable. Others do not meet the expectations as I want to achieve throughput rate 500 kHz for each channel in ADC with 4 channels. Continuous sampling is another critical point.
For example, I have sine waves of 250 kHz in each channels of ADC and want to sample these 4 channels at the same time during 10 miliseconds.
Best,
Fatih
