it is possible to connect the AD7381-4 with an STM 32 with a Q-SPI ?
the STM32 Q-SPI has the standard Q-SPI 6 connections :
- CLK
-nCS
-Data S0 (IO0)
-Data S1 (IO1)
-Data S2 (IO2)
-Data S3 (IO3)
The AD7381-4 has 7 connections
KCC's Quizzes AQQ306 about a fish stick challenge
1. First the quote of the month: " I am so clever that sometimes I don't understand a single word of what I am saying" - Oscar Wilde
2. New quiz AQQ306 about a fish stick challenge:
Here below is a pseudo fish diagram swimming to the right.
Question
Strong EMC design
AD7381-4
Recommended for New Designs
The AD7381-4 a 16-bit, quad, simultaneous sampling, high speed, successive approximation register (SAR), analog-to-digital converter (ADC) that operates...
Datasheet
AD7381-4 on Analog.com
- CLK
-nCS
-Data S0 (IO0)
-Data S1 (IO1)
-Data S2 (IO2)
-Data S3 (IO3)
Hi Seves ,
Upon checking STM32, I think it is still possible interfacing these two (2). But the catch here is, you can only get the output conversion on a single or two (2) digital lines since there is no 3-wire conversion. As stated from its datasheet, you can configure the SDO on having a 1-wire conversion or 2-wire conversion. Since if you will be using all the digital lines of STM32 as SCLK, nCS, SDI, SDOA, SDOB, and SDOC, then the SDOD will be left out. And for that, you need to ground any unused pin as it may induced instability if it is not properly grounded. So, I would still recommend using our controller board, SDP-H, as this was used in testing our boards to meet a guaranteed output.
May I know your application? Since you are using STM32 instead of SDP-H.
Thanks and regards,
Jo
Thank but I have the PCB in production with this micro (STM32F7), and I'm forced to use it.
I'll have to look for another ADC or try to make this one work with STM32...
