Hi ADI expert
I'm going to use the ADR421 as a reference voltage for the AD7682 and other DACs. How much is the reference current when the AD7682 use external reference. Which parameter to see
AD7682
Production
The AD7682/AD7689 are 4-channel/8-channel, 16-bit, charge
redistribution successive approximation register (SAR) analog-to-digital
converters (ADCs) that...
Datasheet
AD7682 on Analog.com
ADR421
Production
The ADR42x are a series of ultraprecision, second generation eXtra implanted junction FET (XFET) voltage references featuring low noise, high accuracy...
Datasheet
ADR421 on Analog.com
Hi ADI expert
Hi licunxu ,
It is stated that it has a 50 uA typical rating for its current when external supply is used.
On the other hand, you need also to take note on these key points to be able to optimize the device when external reference is used. Also, as long as your chosen device for the external reference is within the specs of the suggested parts, then the device will be in its optimal state.
Warm regards,
Jo
Thank you
Hi
If I don't use the input IN3 or IN4, what do I need to deal with it, whether it's float or grounded with a 0Ω resistor
Hi licunxu ,
I recommend tying these pins to ground with a high value resistance (around 10k). It is a best practice to not leave any unused pins as it may induced instability to the output of the device.
Warm regards,
Jo
Hi Jo,
Is the reference ground for VIO analog GND or digital DGND?
Hi Jo
Yes,I will use AD7682 in my sch
HI licunxu ,
May I know your specific application? Having two (2) different ground planes also depends on application. But I suggest following the datasheet and user guide.
But you can also try using these links as your reference:
- Microsoft Word - EDch 12 pc issues.doc (analog.com)
- Staying Well Grounded | Analog Devices
Thank you and regards,
Jo
Hi Jo
Thank you for your suggestion.
My application is temperature sensing. The temperature is detected by detecting the voltage of the thermistor.
