AD5940: External RTIA will be more accurate than internal RTIA with calibration? external oscillator?
Product Number: AD5940
Following up questions from my previous post: (1) AD5940: Offset on the current measurement. - Q&A - Precision ADCs - EngineerZone (analog.com)
Yes.1% is the best accuracy achievable.
0.1% accuracy is not achievable in AD5940 if RTIA, DAC, internal references and internal oscillators are to be used.
I was wondering using external RTIA will be more accurate than using Internal RTIA with Calibration for internal RTIA?
And from my understanding, I am not sure why using external oscillators will improve accuracy as it is used for wakeup timer so it will only used for trigger sequencer periodically.
I did adjust period of wakeup timer(AmpODR ) for multiple phases voltage measurement, but it still works the same for current measurement accuracy under different periods.
float AmpODR;                 /* in Hz. ODR decides the period of WakeupTimer who will trigger sequencer periodically. DFT number and sample frequency decides the maxim ODR. */
Do you mind explaining more on external oscillators?
Appreciate for the help!
Added the product number to the subject field
[edited by: JEstayo at 1:11 AM (GMT -5) on 26 Feb 2024]
