I want to know power supply rejection or sensitivity spec of ADC LTC236x-16.
Can you please help to provide the data? Thanks.
LTC2368-16
Production
The LTC2368-16 is a low noise, low power, high speed 16-bit successive approximation register (SAR) ADC. Operating from a 2.5V supply, the LTC2368-16 has...
Datasheet
LTC2368-16 on Analog.com
Hi Jack1234 ,
The LTC2368-16 has a power-on-reset (POR) circuit that will reset the LTC2368-16 at initial power-up or whenever the power supply voltage drops below 1V. Once the supply voltage re-enters the nominal supply voltage range, the POR will reinitialize the ADC. No conversions should be initiated until 20µs after a POR event to ensure the reinitialization period has ended. Any conversions initiated before this time will produce invalid results.
Thank you.
Red
