## Generated SDC file "DE10STD_DC2390.sdc" ## Copyright (C) 2017 Intel Corporation. All rights reserved. ## Your use of Intel Corporation's design tools, logic functions ## and other software and tools, and its AMPP partner logic ## functions, and any output files from any of the foregoing ## (including device programming or simulation files), and any ## associated documentation or information are expressly subject ## to the terms and conditions of the Intel Program License ## Subscription Agreement, the Intel Quartus Prime License Agreement, ## the Intel FPGA IP License Agreement, or other applicable license ## agreement, including, without limitation, that your use is for ## the sole purpose of programming logic devices manufactured by ## Intel and sold by Intel or its authorized distributors. Please ## refer to the applicable agreement for further details. ## VENDOR "Altera" ## PROGRAM "Quartus Prime" ## VERSION "Version 17.1.0 Build 590 10/25/2017 SJ Standard Edition" ## DATE "Thu Apr 06 18:03:59 2023" ## ## DEVICE "5CSXFC6D6F31C6" ## #************************************************************** # Time Information #************************************************************** set_time_format -unit us -decimal_places 3 #************************************************************** # Create Clock #************************************************************** create_clock -name {altera_reserved_tck} -period 33.333 -waveform { 0.000 16.666 } [get_ports {altera_reserved_tck}] create_clock -name {CLOCK_50} -period 20.000 -waveform { 0.000 10.000 } [get_ports {CLOCK_50}] create_clock -name {FPGA_CLK1} -period 40 -waveform {0.000 20.000} [get_ports {FPGA_CLK1}] create_clock -name {DC2390_ADC:i_DC2390_ADC|sclk} -period 20.000 [get_registers {DC2390_ADC:i_DC2390_ADC|sclk}] create_clock -name {DAC_TOP:i_DAC_TOP|clock_divider2[2]} -period 20.000 [get_registers {DAC_TOP:i_DAC_TOP|clock_divider2[2]}] create_clock -name {DAC_TOP:i_DAC_TOP|clock_divider[1]} -period 20.000 [get_registers {DAC_TOP:i_DAC_TOP|clock_divider[1]}] #************************************************************** # Create Generated Clock #************************************************************** derive_pll_clocks #************************************************************** # Set Clock Latency #************************************************************** #************************************************************** # Set Clock Uncertainty #************************************************************** #set_clock_uncertainty -rise_from [get_clocks {FPGA_CLK1}] -rise_to [get_clocks {FPGA_CLK1}] -setup 0.170 #set_clock_uncertainty -rise_from [get_clocks {FPGA_CLK1}] -rise_to [get_clocks {FPGA_CLK1}] -hold 0.060 #set_clock_uncertainty -rise_from [get_clocks {FPGA_CLK1}] -fall_to [get_clocks {FPGA_CLK1}] -setup 0.170 #set_clock_uncertainty -rise_from [get_clocks {FPGA_CLK1}] -fall_to [get_clocks {FPGA_CLK1}] -hold 0.060 #set_clock_uncertainty -rise_from [get_clocks {FPGA_CLK1}] -rise_to [get_clocks {CLOCK_50}] 0.190 #set_clock_uncertainty -rise_from [get_clocks {FPGA_CLK1}] -fall_to [get_clocks {CLOCK_50}] 0.190 #set_clock_uncertainty -fall_from [get_clocks {FPGA_CLK1}] -rise_to [get_clocks {FPGA_CLK1}] -setup 0.170 #set_clock_uncertainty -fall_from [get_clocks {FPGA_CLK1}] -rise_to [get_clocks {FPGA_CLK1}] -hold 0.060 #set_clock_uncertainty -fall_from [get_clocks {FPGA_CLK1}] -fall_to [get_clocks {FPGA_CLK1}] -setup 0.170 #set_clock_uncertainty -fall_from [get_clocks {FPGA_CLK1}] -fall_to [get_clocks {FPGA_CLK1}] -hold 0.060 #set_clock_uncertainty -fall_from [get_clocks {FPGA_CLK1}] -rise_to [get_clocks {CLOCK_50}] 0.190 #set_clock_uncertainty -fall_from [get_clocks {FPGA_CLK1}] -fall_to [get_clocks {CLOCK_50}] 0.190 #set_clock_uncertainty -rise_from [get_clocks {CLOCK_50}] -rise_to [get_clocks {FPGA_CLK1}] 0.190 #set_clock_uncertainty -rise_from [get_clocks {CLOCK_50}] -fall_to [get_clocks {FPGA_CLK1}] 0.190 #set_clock_uncertainty -rise_from [get_clocks {CLOCK_50}] -rise_to [get_clocks {CLOCK_50}] -setup 0.080 #set_clock_uncertainty -rise_from [get_clocks {CLOCK_50}] -rise_to [get_clocks {CLOCK_50}] -hold 0.060 #set_clock_uncertainty -rise_from [get_clocks {CLOCK_50}] -fall_to [get_clocks {CLOCK_50}] -setup 0.080 #set_clock_uncertainty -rise_from [get_clocks {CLOCK_50}] -fall_to [get_clocks {CLOCK_50}] -hold 0.060 #set_clock_uncertainty -fall_from [get_clocks {CLOCK_50}] -rise_to [get_clocks {FPGA_CLK1}] 0.190 #set_clock_uncertainty -fall_from [get_clocks {CLOCK_50}] -fall_to [get_clocks {FPGA_CLK1}] 0.190 #set_clock_uncertainty -fall_from [get_clocks {CLOCK_50}] -rise_to [get_clocks {CLOCK_50}] -setup 0.080 #set_clock_uncertainty -fall_from [get_clocks {CLOCK_50}] -rise_to [get_clocks {CLOCK_50}] -hold 0.060 #set_clock_uncertainty -fall_from [get_clocks {CLOCK_50}] -fall_to [get_clocks {CLOCK_50}] -setup 0.080 #set_clock_uncertainty -fall_from [get_clocks {CLOCK_50}] -fall_to [get_clocks {CLOCK_50}] -hold 0.060 #set_clock_uncertainty -rise_from [get_clocks {altera_reserved_tck}] -rise_to [get_clocks {altera_reserved_tck}] -setup 0.310 #set_clock_uncertainty -rise_from [get_clocks {altera_reserved_tck}] -rise_to [get_clocks {altera_reserved_tck}] -hold 0.270 #set_clock_uncertainty -rise_from [get_clocks {altera_reserved_tck}] -fall_to [get_clocks {altera_reserved_tck}] -setup 0.310 #set_clock_uncertainty -rise_from [get_clocks {altera_reserved_tck}] -fall_to [get_clocks {altera_reserved_tck}] -hold 0.270 #set_clock_uncertainty -fall_from [get_clocks {altera_reserved_tck}] -rise_to [get_clocks {altera_reserved_tck}] -setup 0.310 #set_clock_uncertainty -fall_from [get_clocks {altera_reserved_tck}] -rise_to [get_clocks {altera_reserved_tck}] -hold 0.270 #set_clock_uncertainty -fall_from [get_clocks {altera_reserved_tck}] -fall_to [get_clocks {altera_reserved_tck}] -setup 0.310 #set_clock_uncertainty -fall_from [get_clocks {altera_reserved_tck}] -fall_to [get_clocks {altera_reserved_tck}] -hold 0.270 #************************************************************** # Set Input Delay #************************************************************** set_input_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 2.000 [get_ports {CLOCK_50}] set_input_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 2.000 [get_ports {FPGA_CLK1}] #set_input_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 2.000 [get_ports {FPGA_CLK2}] set_input_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 2.000 [get_ports {KEY}] set_input_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 2.000 [get_ports {BUSY}] set_input_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 2.000 [get_ports {SDOB}] set_input_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 2.000 [get_ports {altera_reserved_tck}] set_input_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 2.000 [get_ports {altera_reserved_tdi}] set_input_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 2.000 [get_ports {altera_reserved_tms}] #************************************************************** # Set Output Delay #************************************************************** set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {CLK_SYNC}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {SCKB}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {MCLK}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[0]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[1]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[2]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[3]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[4]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[5]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[6]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[7]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[8]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[9]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[10]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[11]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[12]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[13]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[14]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {DAC_DA[15]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[0]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[1]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[2]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[3]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[4]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[5]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[6]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[7]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[8]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[9]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[10]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[11]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[12]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[13]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[14]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[15]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[16]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[17]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[18]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[19]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[20]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[21]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[22]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[23]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[24]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[25]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[26]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[27]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[28]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[29]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[30]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {adc_data24b[31]}] set_output_delay -add_delay -clock [get_clocks {altera_reserved_tck}] 1.000 [get_ports {altera_reserved_tdo}] #************************************************************** # Set Clock Groups #************************************************************** set_clock_groups -asynchronous -group [get_clocks {altera_reserved_tck}] #************************************************************** # Set False Path #************************************************************** #************************************************************** # Set Multicycle Path #************************************************************** #************************************************************** # Set Maximum Delay #************************************************************** #************************************************************** # Set Minimum Delay #************************************************************** #************************************************************** # Set Input Transition #**************************************************************
