AD7740
Production
The AD7740 is a low-cost, ultrasmall synchronous Voltage-to-Frequency
Converter (VFC). It works from a single 3.0 V to
3.6 V or 4.75 V to 5.25 V supply...
Datasheet
AD7740 on Analog.com
Hi everyone,
I need your help about AD7740 output frequency. When VIN is 0V, output frequency is stable and (0.1*Fclk) Hz but if I increase the Vin voltage above about 0.8-0.9V, FOUT is distorted and becomes unstable.
--> It works at VIN=0V correctly.
-->It does not work above 0.7-0.8V level.
Schematic is like that;
We will look into this. I will contact the product owner and get back to you.
JC
Hi hbsts
Good day.
Would it be possible for you to share a link or reference in your circuit design? This is for further details, and we could deduce your queries.
Thank you.
Kind Regards,
Red
Hi
Thanks for your answer. We want to convert a voltage to the frequency by using AD7740. We designed the circuit according to related datasheet. In our application, CLK is good and stable. We also try applying voltage to Pin-CLKIN using voltage follower but result did not change.
Reference link/datasheet:
https://www.analog.com/media/en/technical-documentation/data-sheets/ad7740.pdf
Regards.
Hi hbsts ,
Let me share with you these links, could probably help you to understand the problem you are facing. This is to troubleshoot your setup.
Please check these links:
(+) troubleshooting help - AD7740 - Q&A - Precision ADCs - EngineerZone (analog.com)
(+) AD7740 AD7740: maximum input frequency - Documents - Precision ADCs - EngineerZone (analog.com)
Let me know this helps, or if you still need further assistance let me know.
Many thanks.
Kind regards,
Red
Hi ,
I checked these links but i still need further assistance.
I also contacted engineer working in your company and he gave me advice to place 0.1uF on the REFIN/OUT (pin-4) pin. This helped a little but it was not a complete solution. The IC breaks down after about 16kHz.
Best regards.
Hi hbsts
The part has a maximum input frequency of 1 MHz.
For an analog input signal that goes from 0 V to VREF, the output frequency goes from 10% to 90% of fCLKIN. Can you please share your data with us, epecially the fCLKIN,CLKOUT, VIN and the corresponding Fout.
Thank you.
Kind regards,
Red
Hi
Our design is for 32KHz frequency with external clock at CLKIN pin. We are using CD40106B Schmitt-trigger inverter (You can see our schematics above).
We also know that the output frequency goes from 10% to 90% of CLKIN and it correctly works at 10% frequency (3277Hz) in VIN=0V.
Here are datas you want;
fCLKIN = 32768kHz
CLKOUT = 32768kHz
VIN = 1.8V
FOUT = Distorted signal (You can see it above)
According to this formula in datasheet, for instance, we must measure Fout=(0.1 * 32768) + ( 0.8 * (1.8 / 2.5) *32768) = 22kHz
Thank you
Best regards.
