ad7329 only reading even inputs
Product Number: AD7329
ad7329Range1, 0x1540, AGC_CS8); // ±5V ranges
ad7329Range2, 0x1540, AGC_CS8);
ad7329Sequence, 0x1FE0, AGC_CS8); // Sequence all channels
ad7329Control, 0x1C14, AGC_CS8); // internal reference, 8 channels, full power
I'm setting the control register as shown above. I'm intending 8 single ended inputs, internal reference, ±5V range and continuous sequence all 8 channels.
when I do a read, the upper three bits define the input just read, but they only give even values with occasional 5 and 7. Note below that a2dVoltage[1] and [3] are still 0 as initialized.
What are the address bits in the control register when sequence is set to 01, which I take as run all and thus ignored.
The address bits in Table 12 are confusing or misleading. I can't see why they are there since the Mode 1,0 bits are chip wide settings.
  • Hi  ,
    I think you could try checking your configurations more. Try double checking the configuration for range select.
    Table 12 is there so that you could read a specific channel whenever you will not be using the sequencer mode. (e.g your sequence mode is 0,0). Also, it is a table to guide what mode are you going to use.
    Jo
