MAX291
Production
The MAX291/MAX292/MAX295/MAX296 are easy-to-use, 8th-order, lowpass, switched-capacitor filters that can be set up with corner frequencies from 0.1Hz to...
Datasheet
MAX291 on Analog.com
MAX295
Production
Datasheet
MAX295 on Analog.com
Goodmorning, I need a variable frequency anti-alias filter for precision ADC (due I need different output sampling rates).
I need to provide signal path for my ADC so I need a model for my anti-alias filter.
Taking as reference MAX291/295 datasheet I can reproduce MAX 295 model with python:
A0 = 4.20769896658e+29*5.77290333605
zeros = []
poles = []
poles.append(-1225.78864486+6162.45566333j)
poles.append(-1225.78864486-6162.45566333j)
poles.append(-3490.75072522+5224.27765139j)
poles.append(-3490.75072522-5224.27765139j)
poles.append(-5224.27765139+3490.75072522j)
poles.append(-5224.27765139-3490.75072522j)
poles.append(-6162.45566333+1225.78864486j)
poles.append(-6162.45566333-1225.78864486j)
k = A0
z = zeros
p = poles
# passo da zpk a tf
[b, a] = signal.zpk2tf(z, p, k)
w, h = signal.freqs(b, a) # andamento ideale del filtro
f = w/(2*np.pi)
legenda = []
#amp_mio=20*np.log10(np.abs(h))
plt.title("MAX295, fclk=50kHz")
plt.plot(f, 20 * np.log10(abs(h)))
legenda.append("F=1kHz")
plt.axhline(-3, linestyle='--', color='r')
plt.ylim(-140,20)
plt.grid()
plt.legend(legenda)
#plt.xlim(4,15)
plt.xlim(0,5000)
plt.xlabel("frequency [Hz]")
#plt.xscale('log')
plt.show()
I can't reproduce model of MAX291 due at 5 kHz (page 4, second graph) attenuation is lower than MAX295.
BTW, on that graph scale is wrong: Hz instead kHz.
How can I get model (paz) of MAX291?
Thanks.
Only Maxim ATE products are supported on EngineerZone at this time. Over the next several months, you will see more Maxim products being supported in EngineerZone. Please visit one of the technical support pages on our newly integrated website below for assistance with Maxim Integrated products.
EN - https://www.analog.com/en/support/technical-support.html#
CN - https://support.analog.com/zh-CN/technical-support/
JP - https://support.analog.com/ja-JP/technical-support/
JC
