Hi all,
I am looking for some standard code / library for mentioned adc. Can anyone point me in the right direction?
AD4129-8
Recommended for New Designs
The AD4129-8 is an ultra-low power, high precision, measurement solution for low bandwidth battery operated applications. The fully integrated analog front...
Datasheet
AD4129-8 on Analog.com
AD4130-8
The AD4130-8 is an ultra low power, high precision, measurement solution for low bandwidth battery operated applications. The fully integrated analog front...
Datasheet
AD4130-8 on Analog.com
Hi all,
The AD4129-8 uses the same samples codes as AD4130-8. You may refer to the following:
AD4130 IIO Application [Analog Devices Wiki]
You may also refer to the AD4130-8 product page for more information: AD4130-8 Datasheet and Product Info | Analog Devices
Thanks and regards,
Rod
