KCC's Quizzes AQQ306 about a fish stick challenge
1. First the quote of the month: " I am so clever that sometimes I don't understand a single word of what I am saying" - Oscar Wilde
2. New quiz AQQ306 about a fish stick challenge:
Here below is a pseudo fish diagram swimming to the right.
Question
Strong EMC design
ADAQ8092
Recommended for New Designs
The ADAQ8092 is a 14-bit, 105 MSPS, high-speed dual-channel data acquisition (DAQ) μModule® solution. The device incorporates signal conditioning, an...
Datasheet
ADAQ8092 on Analog.com
I'm trying to get the EVAL-ADAQ8092-FMCZ board running on a Zedboard carrier using the Kuiper image. However the LD7 LED doesn't start flashing. I tried both the SD card that came with the board and a new one that was flashed accoring to the Wiki pages using the reccomended softwares, even checking the MD5 signatures. One thing I am not quite sure about is the setting of the VADJ Jumper. It just says "To avoid potential damage, ensure the VADJ SELECT jumper is set to the correct voltage for the Product Evaluation Board." But it doesn't state which is the correct setting. As the data sheet states ODD = 1.8V I set the jumper to that position. Is that right?
If that setting is correct what else could be the reason for the board not booting correctly?
Thanks and kind regards
Nico
Hi Nico638 ,
Let's try to use first the SD card that came together with the evaluation board. I recommend doing the following:
Let me know if this will work on your end. Please feel free to send updates in this thread so we can see if it will work. Thank you very much!
Kind regards,
Chelsea
Hi Chelsea,
thank you for the quick and detailed answer. I won't be able to try it until Tuesday though , but will get back to you then.
Kind regards,
Nico
Hi Chelsea,
I tried changing the VADJ jumper. While that didn't do anything, I also reflashed the SD cards with the Kuiper image from 28 July 2022 and setting it up with the generic zedboard image. That did boot the board. I could also connect via Serial (connecting to the UART header J14 not USB_OTG J13 as told in documentation).
After changing to the ADAQ8092 configuration via console the board still boots and lets me connect, but the LED doesn't flash and it it can still not be found by ACE. I also tried reinstalling ACE and/or the IIO WCF Wrapper.
Do you have any further advice?
Kind regards
Nico
Hi Nico638 ,
The best option is to use the SD card that came together with the evaluation board, and the few things to note here are:
If you are using the Kuiper Image from July 28, then I suspect that it has something to do with the process on configuring the image file itself. Re-imaging the SD card requires additional steps, let me know if you have done these as well:
Link: ADI Kuiper Linux with support for Evaluation [Analog Devices Wiki]
I'll also try to replicate your setup on my end and discuss the additional steps in detail once done. Thank you and feel free to update on this thread.
Chelsea
Hi Chelsea,
I did install the plug-in and also followed the steps in the screenshot/guide. command iio_info also states that it is configured for the ADAQ8092 card.
I am free to use whichever version of Kuiper you reccomend/works. I just figured that version is the correct one because it explicitly states that it is suitable for ACE.
Regards, Nico
Hi Nico638 ,
I have tried re-imaging the SD card on my end. Here are the additional steps you may try:
Let me know if this works on your end. Thank you very much!
Chelsea
Hi Chelsea,
the USB-OTG enabling seems to have been the problem. The Board is up and running now. It is still not always recognized, but after one or two reboots, it shows up.
Thank you very much,
Nico
One more question not directly related to this issue: Is there a reason, the holes at the FMC connector of the ADC board don't line up with those on standard FMC carriers? We have a EVAL-AD7606C-FMC board here which does fit both the Zedboard and the SDP-H1, but those of the ADAQ8092 don't.
Hi Nico638 ,
Glad to hear that your setup is working already. We'll also include the USB-OTG enabling in future documentations regarding re-imaging the SD card.
By the way, there is no other meaning behind the holes of the board, this was overlooked during the previous releases. But we have already updated the layout of the board that matches the holes of the Zedboard and SDP-H1, reflected in Rev. C (please see photo below).
Thanks and kind regards,
Chelsea
