Hi All
We are doing error budget for our circuit , for that we like to know the sink currents on each AIN Pins,
Thanks for Quick support
AD7124-4
Recommended for New Designs
The AD7124-4 is a low power, low noise, completely integrated analog front end for high precision measurement applications. The device contains a low noise...
Datasheet
AD7124-4 on Analog.com
Hi All
Hi SundarSingh1 ,
May we know your application and adc configuration for this?
What do you mean by sink current? Are you pertaining to the currents that the ADC can accept, or is it the currents from your AIN pins?
Thanks and regards,
Rod
Hi Rod
We are using the ADC for reading thermocouple(~10 -2.5mV ), we like to know the current that flows into Ain PIN or Input Impedance value
Thanks
Sundar
Hi Sundar,
The current that flows into AIN pin (Analog Input Current) depends on your configuration of the ADC power mode, buffer, and gain. You may refer to table 3 below from the datasheet (AD7124-4 (Rev.E) (analog.com)).
Thanks and regards,
Rod
