We’ve been trying to use SensorPal and the AD5940 eval board to do Cyclic Voltammetry of an electrode and correlate the parameters to that in the code.
This was the graph obtained on the Potentiostat we are using with Three Electrode system, Solution- K3FeCN6 and following settings
However while trying to replicate the same on the sensor Pal, I am getting a graph like this.
I am not sure what the step potential in the CV parameter means. Does it relate to the 'Sample at interval of ' parameter in the above potentiostat picture. Can you help me out with this. Also how do I correlate the sensorPal parameter settings in the code. For example I can't find anything called scan rate in the CV example code.
