MAX11410
Production
The MAX11410 is a low-power, multi-channel, 24-bit delta-sigma ADC with features and specifications that are optimized for precision sensor measurement...
Datasheet
MAX11410 on Analog.com
AD7175-8
Recommended for New Designs
The AD7175-8 is a low noise, fast settling, multiplexed, 8-/16- channel (fully/pseudo differential) S-? analog-to-digital converter (ADC) for low bandwidth...
Datasheet
AD7175-8 on Analog.com
Hi
I am new to electronics world and here to ask help to suggest me an ADC for my application.
I want to make a Breakout Board to be interfaced with ESP32 to make a data logger. I would prefer 8 inputs though 4 would be considered and each input may of either 4-20mA or PT-100 (RTD) or Thermocouple.
Someone suggested me ADS1115 and INA105 but I see other ADC with better resolution in the market. Please give me your suggestion based on your practical experience. Thanks
You may check out AD74412R Datasheet and Product Info | Analog Devices
Hi Akila
Thank you for your answer!
You may also want to consider AD4110-1 Datasheet and Product Info | Analog Devices with external mux in front for example ADGS1208 Datasheet and Product Info | Analog Devices.
You can also ask someone from (+) Q&A - Switches/Multiplexers - EngineerZone (analog.com) what mux option will suit your requirements.
Another option is AD7124-8 Datasheet and Product Info | Analog Devices it has most of the building blocks needed for RTD and Thermocouple measurement though it does not have a direct current input, but you can add external sense resistor.
Jellenie
Hi Jellenie
Thank you very much for your answer !
