We are using LTC2495IUHF IC in our design. Could you please help in reviewing the schematic.
PDF
LTC2495
Production
The LTC2495 is a 16-channel (eight differential), 16-bit, No Latency ΔΣ™ ADC with Easy Drive technology and a 2-wire, I2C interface. The patented...
Datasheet
LTC2495 on Analog.com
PDF
Hi RamyaRaviCapgemini ,
We will look into this. I will contact the product owner and get back to you.
JC
May I know why are the address lines tied mid rail through a voltage divider?
JC
It is to provide option to select either 1 or 0 for address pin. Either pull up or pull down resistor will be mounted. another resistor will be in DNP(Do not populate).
We have reviewed the schematic and it looks fine on our end. You may also refer on the schematic on the user guide for your reference.
Link: DC1012A-LTC2499/LTC2497/LTC2495 Evaluation Kit Quick Start Guide (analog.com)
JC
