AD7381-4
Recommended for New Designs
The AD7381-4 a 16-bit, quad, simultaneous sampling, high speed, successive approximation register (SAR), analog-to-digital converter (ADC) that operates...
Datasheet
AD7381-4 on Analog.com
The AD7381-4 uses an enhanced SPI digital interface with CS, SCLK, SDI, and 4 SDO pins to be used in maximum throughput mode.
This SPI interface is different from the standard SPI or QSPI interfaces which most microcontrollers are compatible with
Thank you
We'll contact the product owner and get back to you.
Andrei
We use FPGA to maximize speed and versatility and optimize performance. As of now, we haven't used or tested any microcontroller that has a higher capability in terms of speed.
I've seen some user uses the STM32 controller for the AD7381-4 but we haven't explored or tested this yet. I suggest you can check the link below and refer to github forum.
Andrei
