LTC2327-16
Production
The LTC2327-16 is a low noise, high speed 16-bit successive approximation register (SAR) ADC with pseudo-differential inputs. Operating from a single 5V...
Datasheet
LTC2327-16 on Analog.com
We will look into this. I will contact the product owner and get back to you.
JC
Thank you.
Hi JC,
Any feedback? Thanks.
Hi JC,
Yes, we computed the FS error drift and we come up with around 1.9 to 2 ppm/C. I'll clarify this to the product owner soon.
Andrei
1.The curve is for a typical part. The spec is for a worst case part which can be much worse than a typical part.
2.If a REFIN or REFBUF is specified or Note9 is present an external reference is used.
3. There is no PSRR information available. Use recommended bypassing and a low noise regulator to power the ADC and data sheet performance should be achieved.
