AD598 output voltage does not give a constant voltage.
Based on the circuit I shared below, I tried different resistors and capacitors, but I did not get the result I expected.
At best, its output value changes with the movement of the lvdt, but when the lvdt is idle, the output voltage drops continuously.
(Every time I turn on the supply, it started from 2.3V and decreased to 2V within 5 minutes.)
Yours sincerely
