Is there a replacement for the AD7793 with the same pinout?
May I know what is your application and what is the reason for replacement? I think AD7792 is the pin-pin compatible of AD7793 but with 16bit of data conversion only. You can also check it co-family…
Hi Diego,
I see I think the above co-generics may suit your needs. Though some of these have higher channel counts that you may find it overkill for your application.
Jellenie
May I know what is your application and what is the reason for replacement? I think AD7792 is the pin-pin compatible of AD7793 but with 16bit of data conversion only. You can also check it co-family AD7794/95/96/97/98/99
However, the recommended replacement for these parts is the AD7124-4B which is not a pin-pin compatible but with it has all the building blocks of the AD7793 and with more advanced features.
Jellenie
Thank you very much for your reply.
Reason for replacement is because the AD7793 is out of stock at Mouser and Digi-key.
Diego
Hi Diego,
Jellenie
Hi Diego,
Jellenie
