AD74412R 在CURRENT INPUT EXTERNALLY POWERED模式下adc值异常
ad74412r的其他模式下,工作正常,adc值读取符合预期。
但是在CURRENT INPUT EXTERNALLY POWERED模式下adc值异常,当外接电源输出1-4ma时(即ad74412r输入电流为1-4ma时),读取的adc值的范围0x300至0xcb00。
当然后增大电流时,adc又从0x1000上升到0xcb00范围。
输入电流:2ma adc code:0x3a92
输入电流:3ma adc code:0x72c0
输入电流:4ma adc code:0xa8ba
输入电流:4ma adc code:0xa955
输入电流:5ma adc code:0xcf2b
输入电流:6ma adc code:0xf546
输入电流:7ma adc code:0x6557
输入电流:8ma adc code:0x33c5
输入电流:9ma adc code:0x30ad
输入电流:10ma adc code:0x2cec
输入电流:11ma adc code:0x1e21
    would it be possible to know more about your setup?
    What is exactly is connected as current input at this channel? What is the value of the ADC_CONFIGx register for the channel you are using in this setup?
    Arnost
  • Sorry, there is something unusual about my account and I didn't reply in time.
    A signal generator is connected to this channel, the signal generator is set to current output mode.
    I set CH_FUNC_SETUPx to 0x4, set ADC_CONFIGx to 0x21, turn on ADC continuous conversion, and can read
    the value of adc. but the value of adc is not as expected. The code I use is your official sample code.
  •        I/OP_x and I/ON_x voltage     Rsense voltage
    input current 1ma, adc code:6753 (decimalism)            0.9v                                  0.1v
    input current 2ma, adc code:20161
    input current 3ma, adc code:44071
    input current 4ma, adc code:54154
    input current 4.5ma, adc code:59038
    input current 5ma, adc code:60497                               1.44v                              0.5v
    input current 6ma, adc code:12454
    input current 7ma, adc code:9995
    input current 8ma, adc code:5737
    input current 9ma, adc code:126
    input current 10ma, adc code:0                                        2.3v                              1v
    input current 11ma, adc code:0                                         2.47                            1.1v
    input current 12ma, adc code:1251
    input current 13ma, adc code:34076
    input current 14ma, adc code:36696
    input current 15ma, adc code:39315
    input current 16ma, adc code:41937
    input current 17ma, adc code:44568
    input current 18ma, adc code:47189
    input current 19ma, adc code:49812
    input current 20ma, adc code:52434                            4v                                       2v
    The voltages of terminals I/OP_x and I/ON_x increase monotonically.
    The voltage across the sampling resistor also increases monotonically.
    The voltage of the sampling resistor is as expected
    thank you for the clarification concerning the setup.
    Can you please confirm, that the data indicated above are read directly from the ADC_RESULTx register (Address: 0x26 to 0x29 - depending on the used channel).
    Arnost
  • I'm sure I'm reading the value of the corresponding channel at register addresses 0x26 to 0x29.
    are you using your own board or EVAL-AD74412R board?
    # Would it be possible to check the following board voltages: AVDD, AVSS, REFIN, REFOUT, ALDO1V8, ALDO5V, DVCC, IOVDD.
    Please provide measured voltages.
    # Could you please provide data from the following procedure:
    1. Reset the part
    2. Clear Alert Status register (Address: 0x2E, Reset: 0x8000, Name: ALERT_STATUS)
    3. Configure part as needed (CH_FUNC_SETUPx, ADC_CONFIGx)
    4. Read ADC measurements
    5. Read alert status again  (Address: 0x2E, Reset: 0x8000, Name: ALERT_STATUS)
    And provide ADC measurements, including the value of the ALERT_STATUS register.
    Arnost
  • thank you very much!
    Haven't dealt with this for a long time.
    According to your hint, I got the CHARGE_PUMP_ERR error. Then check the schematic and find that AVSS is directly grounded. Now that the AVSS is cut off from the ground, the situation has improved.
    now  0x2E,ALERT_STATUS is 0.
    The measured value is now linear in this mode, but the calculated value is much smaller according to the formula 2500*adc/(65535*100).
    input:4ma    get:2.4ma
    input:8ma    get:5ma
    input:12ma    get:6ma
    input:16ma    get:10ma
    input:20ma    get:12ma
    DVSS=5.13V
    AVSS=-4.39V,In the chip manual AVSS = NEGATIVE DVCC.
    Excuse me, is this caused by the AVSS not being connected to the capacitor?
  • We cut off the AVSS from the ground, and connected the capacitor, and it was normal. thank you very much.
    Do I understand correctly, that connecting AVSS to the corresponding pin and adding the necessary capacitor was the solution to your problem?
    Is there something more I can help with?
  • yes,Thanks for your help, no more questions. .
