ADC data read from AD4111
Hi all,
I am facing the issue regarding ADC data read from the AD4111 device
Hardware setup:
  1. EVAL-AD4111/12SDZ Board
  2. PIC microcontroller
  3. The temperature sensor (4-20mA output) is connected to IIN0 and GND terminals of  EVAL-AD4111/12SDZ Board
Programming
  1. SPI mode 3
  2. SPI communication between EVAL-AD4111/12SDZ board and PIC micro is working
  3. I can read the device id (0x30DE)
  4. I can write and read the register values
AD4111 Configuration data used in the project
ADCMODE = 0x01 0x01 0x0C
IFMODE = 0x02 0x00 0x40
GPIOCON = 0x06 0x34 0x00
CH0[] = 0x10 0x91 0xE8
SETUPCON1 = 0x21 0x00 0x00
FILTCON0 = 0x28 0x0A 0x0A
GAIN0 = 0x38 0x00 0x00 0x00
I am not able to get the ADC data corresponding to the sensor input. The ADC data I am getting is around 0x6FDB38 for the entire input range 4mA to 20mA. Please check and let me know if I have missed any configurations.
I have shared the screenshots of device configuration write operation, device configuration read operation, Device id read operation and ADC data read operation for your reference
Thank you for your time
Amar
    Can you double check the register settings please. For example you displayed data for FILTCON0 and GAIN0 but you have used SETUPCON1. And one more thing, why is the GAIN0, all 0s? Did you write anything on this register, the default value must be 0x5XXXX0. Changing this will affect the gain error in your conversions.
    Jellenie
  • Hi JellenieR,
    Thanks for your reply,
    I have modified the register setting as per your suggestion, but am still not able to get the correct ADC values.
    CH0 = 0x10 0x81 0xE8
    SETUPCON0 = 0x20 0x00 0x00
    I have attached the screenshots for your reference
    ADC data for 5mA current input
    ADC data for 8mA current input
    Thanks for your time
    Amar
  • Hi Amar,
    I also noticed you have put a delay in the ADCMODE register, do you have external circuitry on this? Can you share your schematic please?
    Have you also followed the allowable common mode input range for current inputs? Looking at the output code, the equivalent current input is around 21mA. Is it possible for you to measure your actual input please with a current meter? This is just to ensure that the input are changing?
    Jellenie
  • Hi Jellenie,
    Thanks for your replay,
    I have removed the delay but no change, the problem remains the same.
    No
    please find the hardware setup block diagram for your reference
    Yes, the sensor output is in the range of 4-20mA
    The ADC data shared in the previous reply was  5mA and 8mA respectively
    I have measured the input current using  Fluke 117 multimeter, I checked with the input from 5mA to 12mA, but the output ADC value remains the same. please find the screenshots for your reference
    For Input 8mA
    For input 12mA
    please let me know if you need further information.
    Amar
  • Hi Amar,
    I was thinking if you can also measure the common mode voltage between IIN0+ to IIN0- (GND_ISO)?
    And can you also clarify the supply section? My understanding here is that you supply the EVAL-AD4111/12 using J7 (LK3 is A)?
    Regarding the scope shot, it is interesting that you are reading the data register when the RDY bit of the status is low. Please take note that when RDY bit is high it means that it is still awaiting new data conversion results. So you need to wait for RDY to go low before attempting to read data conversion.
    Jellenie
  • Hi Jellenie,
    AD4111 register Configuration to measure common-mode voltage between IIN0+ to IIN0- (GND_ISO)
    ADCMODE = 0x01 0x00 0x0C
    GPIOCON = 0x06 0x00 0x00
    CH0 = 0x10 0x80 0x10
    SETUPCON1 = 0x20 0x03 0x00
    My observations are as follows
    1. When I am writing and reading to configuration registers in an infinite loop and reading the STATUS REGISTER
    • The RDY bit of STATUS REGISTER remains high for all the read operation
    • ADC data (0x8FD113) will remain the same for 0v to 8v input range
    Screenshots:
    Code:
    void main()
           Sys_config();
           Delay_1ms();
           Delay_1ms();
           Delay_1ms();
           Delay_1ms();
           Delay_1ms();
           Write_Reg();//Write to REGISTER
    while(1)
        while(cnt == 0x64) // Read/write the registers for every 100 count
            Delay_1ms();//1 ms delay
            Read_Id();   //Read device ID
            Read_Reg();//Read the REGISTER valus
            cnt = 0;
        cnt++;
        Read_StReg();//Read the STATUS REGISTER
        Data_Ready = (Staus_Reg_Data & 0XFF);
        if(!Data_Ready)// RDY = 0, ADC_ERROR = 0 , CRC_ERROR = 0, REG_ERROR = 0 and channel selected is CH0 = 0000h
         Read_ADC_Data();//Read ADC Data
        Read_StReg()
        CS_SetLow();// Chip Select to LOW
        SPI1CON0bits.EN = 1;//Enable SPI
        SPIExchangeBlock(RdStReg,sizeof(RdStReg));//Data exchange
        SPI1CON0bits.EN = 0;//Disable SPI
        CS_SetHigh();// Chip Select to High
        Staus_Reg_Data = readDataStr[1];//Copy Status flag data
    Read_ADC_Data()
        SPIExchangeBlock(RdDATA,sizeof(RdDATA));//Data exchange
    2. When I am writing the configuration registers before the infinite loop, reading the REGISTERS and STATUS REGISTER
    • STATUS REGISTER will be 00H for all the read operations (RDY bit is Low)
    • The configuration REGISTERS values read from the ADC are different from what we have written
    ADC Data for 0v to 8v input
    Sl No
    IIN0+ to IIN0- (GND_ISO) Voltage
    ADC Value
    1
    0
    0x705056
    2
    1
    0x743D57
    3
    2
    0x77F24A
    4
    3
    0x7BFFDF
    5
    4
    0x7FE3F1
    6
    5
    0x83EA2B
    7
    6
    0x87CE5D
    8
    7
    0x8BCC9F
    9
    8
    0x8FE5A6
    Screenshots:
    2V input
    8V input
    Code:
    void main()
          Sys_config();
           Delay_1ms();
           Delay_1ms();
           Delay_1ms();
           Delay_1ms();
           Delay_1ms();
    while(1)
        while(cnt == 0x64) // Read the registers for every 100 count
            Read_Id(); //Read Device ID
            Read_Reg();// Read the registers
            cnt = 0;
        cnt++;
    Yes, for supply I am using J7(LK3 is in A position)
    I have tried to get the ADC value with following register configuration
    AD4111 register Configuration as below
    IFMODE = 0x02 0x00 0x00
    SETUPCON1 = 0x20 0x00 0x00
    My observations as follows
    Screenshots:
    Code:
    Code:
    while(1)
        while(cnt >= 0xff)
            Read_Reg();
            cnt = 0;
        cnt++;
         	Read_ADC_Data();
    Read_StReg()
        SPI1CON0bits.EN = 1; //Enable SPI
        SPI1CON0bits.EN = 0;// Disable SPI
        CS_SetHigh();//Chip Select to High
        Staus_Reg_Data = readDataStr[1];//Copy the Status Register data
    Read_ADC_Data()
    • The REGISTERS values read from the ADC are different from what we have written
    Screenshots:
    Code:
    void main()
           Sys_config();
           Delay_1ms();
           Delay_1ms();
           Delay_1ms();
           Delay_1ms();
           Delay_1ms();
    while(1)
            Read_Reg();
            cnt = 0;
        cnt++;
         Read_ADC_Data();
    My Questions:
    1. The REGISTER write operation can be called in any part of the program? Is it affects the data conversion operation?
    2. If you have any specific steps or flow related to write/read operations coding, pls let me know
    3. let me know the calibration steps
    Amar
  • Hi Jellenie,
    I haven't get any response.
    Regards
    Amar
  • Hi Amar,
    Apologies as I have missed this query.
    Regarding your questions,
    We have suggested configuration flow provided in page 23 of the datasheet. We also have example code that you can use as a reference. Please see links below.
    AD717X No-OS Software Drivers [Analog Devices Wiki]
    AD717x/AD411x Mbed Example [Analog Devices Wiki]
    In terms of calibration, page 38 of the AD4111 (Rev. B) Datasheet also detailed the different calibration modes and procedure. I think the Mbed example code have a calibration demo feature that you can check.
    Jellenie
