Hi all,
Can I use EVAL-AD738xFMCZ to evaluate AD4680 while just replacing AD738x with AD4680?
I think they are the same package and pin-compatible, but there is no AD4680 ACE Plugin, so how should I evaluate AD4680?
Leo
Hi all,
Leo
It is possible to evaluate the AD4680 using a EVAL-AD738xFMCZ since they are pin to pin compatible. For the evaluation software such as ACE plugin, I can contact the product owner and get back to you.
Andrei
I am looking forward to your update.
Hi QYQ,
Yes, you can use the AD4680 with the EVAL-AD738xFMCZ board. You can also use the AD7380 plugin. The ACE software will detect the board as AD7380 but you can run the AD4680 from it. You just need to change the sampling rate in the software plugin to fit into the AD4680 specification.
Jonathan
Hi Jonathan,
Thanks a lot!
Hi Jonathan,
I have another question about the difference between AD4680 and AD7380.
I found the oversampling mode is also different between both except the sampling rare, AD7380 has normal average and rolling average, but AD4680 only has rolling average, is it correct? does the AD7380 plugin work well with AD4680?
If there are any other function differences, please let me know.
Kind Regards,
