Hi all,
I want to know the PSRR of LTC2324-14, could I get some specifications for that?
Now I am considering using a switching regulator power supply for LTC2324-14.
Best Regards,
Leo
LTC2324-14
Production
The LTC2324-14 is a low noise, high speed quad 14-bit + sign successive approximation register (SAR) ADC with differential inputs and wide input common...
Datasheet
LTC2324-14 on Analog.com
Hi all,
Best Regards,
Leo
For the switching regulator, what is your required input voltage?
Andrei
Thanks.
I am thinking of using 15V to make 5V for VDD of ADC, 15V is from ACDC converter.
Leo
I'm not sure if there is PSRR data available for this.
We do not usually recommend a switching regulator to supply precision ADCs as it may introduce switching noise. We usually used an LDO following the switching regulator. However, if this is not suitable for you. I would recommend to ask Q&A - Power By Linear - EngineerZone (analog.com) community as someone there can better assist you.
Jellenie
Hi Jellenie,
I found some Legacy ADI products provided with PSRR data, but this Legacy LTC has no data.
As you said, LDOs are suitable for ADCs.
Thank you for your support.
