hi, engineers
as you know, if the gain is changed, we should calibrate the device.
my problem is:
i use the same gain, always fixed gain. but i will change the configuration: fist step, i will sample with buffer off. then i will sample again with buffer on because of the common voltage input range reason.
i don't know if i need calibrate when i change the buffer from off to on (or on to offf)?
best regardings.
