External power supply for EVAL-AD7606CFMCZ
I recently bought a EVAL-AD7606CFMCZ and I want to integrate it with an Arduino or RPi. In the Power supply section in Evaluation Board Hardware section of the user guide (https://www.analog.com/media/en/technical-documentation/user-guides/eval-ad7606c-fmcz-ug-1870.pdf), it is mentioned that I need to supply the power to P4 terminal block. I do not see any P4 terminal on the board nor in the layout file provided (https://www.analog.com/media/en/technical-documentation/eval-board-schematic/eval-ad7606c18fmcz-layout.pdf).
I would like to know how to power up the evaluation board using external power supply. Is it possible using the Vin? How much voltage must be provided? Can I directly connect 5V to AVcc on P3 to power the eval board? Any help would be appreciated.
Thanks & Regards,
Srivamsi Malladi.
