September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
AD7609
Production
The AD7609 is an 18-bit, 8-channel, true differential, simultaneous sampling analog-to-digital data acquisition system (DAS). The part contains analog...
Datasheet
AD7609 on Analog.com
Is the AD7609 designed to withstand active analog input voltages (of up to +/-16V) while the device itself is powered-down?
I'm not sure about the internal clamping circuit. Is this an active circuit that needs a proper power supply to work as intended?
Thank you.
The protection should work in normal or power-down mode. However, when device is powered-down I think it is recommended to tie both inputs to GND. The overvoltage clamp is use for transient overvoltage condition and not recommended to be active for extended periods in either mode (normal or power-down) as stressing the part outside range may degrade the Bipolar Zero Code error and THD performance as stated in the datasheet.
Jellenie
