We are using LTC2400 interfaced with NXP LPC1768 microcontroller and manually controlling SCK and reading SDO lines.
As mentioned in the datasheet, we are following the sequence as shown below,
CS-> Low
Check SDO pin value,
if == 1, CS=High , Return
else Clock SCK 32 times , read the pin value of SDO
CS=High
Remove last 4 bits of SDO data and mask first 4 bits of data , use the remaining
But the converted data is continously flactuating even when analog input line is connected to ground.
Where are we going wrong?
