AD7768-1 Raw modulator output for FPGA post-processing
Is there an option to enable a raw modulator output feature?
In the datasheet there's the flag "MOD_OUTPUT" with no clear description what it means. If this enables the modulator output on which interface pins is it available?
Parents
    on May 18, 2021 10:19 AM
    hi
    there is mod output mode on the AD7768-1, but note that its only available in low power mode. Note that we have minimum tests on this feature
    Pseudo Algorithm would be
    ►Configure the part via SPI as desired
    ►Put part into Modulator output mode, using MOD_OUTPUT bit in Register 0x15.
    ►Enable continuous read mode.
    ►The 8 modulator data bits are available after DRDY in address 0x2c.
    ►The first bit available to read is mod_data[7], so only 8 SCLK s are needed.
    ►DRDY will be pulsed indicating updated data, so SCLK needs to be fast enough to throw out the bits
    ►Max DRDY supported is 1.024 MHz.
    ►POWER_MODE is fixed at ECO
    thanks
Reply
    hi
    thanks
Children
No Data
