Some questions about AD7783
Hi
I used AD7783 in my new design to convert the analog signal which is from front-end sensor.
When I go through the datasheet, I can't find any description regarding the internal registers and the waveforms defined on the serial data.
I can't find any related information in this on-line forum either. Could you help clarify these questions.
Regards
    The AD7783 is a read only and pin configuration ADC. The only register that you can access is the data register for data output code. You can configure the part in slave or master mode in order to perform the reading via mode pin. I think the datasheet provide the information on how to read the data register in either mode.
    Jellenie
