LTC2326-16
Production
The LTC2326-16 is a low noise, high speed 16-bit successive approximation register (SAR) ADC with pseudo-differential inputs. Operating from a single 5V...
Datasheet
LTC2326-16 on Analog.com
Dear,
My LTC2326-16 only display +/-5V when reading using arduino
I tried to read many topic but i did not find any related one.
First I connect the LTC 2326 correctly with internal reference, I have measured REFIN 2.048V and REFBUF 4.096V -> correct
Secondly, the chip is soldered correctly,
Thirdly, I use the Arduino library to communicate with LTC2326-16
//===================== int16 ==================== 15bit with 1 bit signed to read from LTC2326 ======
int16_t LTC2326_16::read()
int16_t val;
digitalWriteFast(_cnv, LOW); // Reset CNV for another conversion later on
SPIFIFO.write16(0);
val = SPIFIFO.read();
return val;
NOTE that : int16_t from -32768 : 32767
By applying IN+ and IN- I have some value
(IN+ - IN-) = 2.09V :: VAL = 13406
(IN+ - IN-) = -2.09V :: VAL = -13408
(IN+ - IN-) = 5.09V :: VAL = 32574
(IN+ - IN-) = -5.09V :: VAL = -32294
(IN+ - IN-) = 6.09V :: VAL = 26542 ->> ???? WHY
(IN+ - IN-) = -6.09V :: VAL = 27650 ->> ???? WHY
According to the setup, REF internal is used, (IN+ - IN-) should have +/-10.24V range.
However, when the input voltage is higher than 5.1V, the ADC value is reduced (see 6.09V case)???
As I understand, The output data is in 2’s complement format, does it affect my reading
Sorry for my bad English,
could you please help me??
thank you so much
Is IN- grounded? This is a pseudo-differential part so IN- must remain within 500mV 0f GND.
You may not be properly decoding the ADC output. Can you provide an oscilloscope photo that shows CNV, BUSY, SCK and SDO during one conversion cycle? Also provide the IN+ and IN- voltages for this conversion.
Dear ,
In order to test the +/- IN , I use the isolated controllable power supply
Therefore, IN- is safe and the voltage different between Ground is not high.
I am thinking that the issue may come with my code, and I am testing it. Thank you for your reply
