Ad7927 has abnormal voltage jump of channel 0
The abnormal voltage jump of channel 0 occurred in our application, which occurred in many projects. Attached are our own test results and problems
Test conditions
Test condition description
Ad value status
Filter pool status
Report voltage value
Normal state
Normal state
All channels are normal
The software writes 0x0800 to ADC
Simulate default state
Only 0 channel value can be adopted
It jumps periodically between 0 and channel voltage. Because of the complement problem, the acquisition value is too large
Channel 0 jumps periodically between 313 V and 313 + true value / 2, while the voltage of other channels remains unchanged
The software writes 0x0840 to ADC
Simulate the default state and change the channel to 1 channel
Only one channel value can be taken
It jumps periodically between 1 and channel voltage. Because of the complement problem, the acquisition value is too large
One channel changes periodically between 313 V and 313 + true value / 2, while the voltage of other channels remains unchanged
The software writes 0x0870 to ADC
Analog default state, 1 channel, power mode changed to 11 (00 is illegal, 11 is normal application)
Stable acquisition
1 channel acquisition value = 313 + true value / 2, the other channel voltage is unchanged
Normal state, short circuit ADC power supply during operation
Analog ad power down
The power down test state of analog ADC is consistent with the state of software writing in 0x0800, so it is suspected that 00 is the default state of chip register after power on. In this state, the channel is 0, and the power mode is illegal. The output ad value will jump back and forth between the real voltage and 0. However, due to the problem of complement, the software will be too large after calculation. At this time, if the voltage mode is written, the chip will work normally without voltage jump.
Question 1: is the default state of the chip 00?
Question 2: is the state of pm01 related to ad jump?
Question 3: in the state of 0x0800 or power failure recovery, why does the ad value jump between the real value and 0?
Question 4: is there any other reason or abnormal condition that can enter this fault state? Such as: power overvoltage, undervoltage, long time no communication or frequent communication, communication error, etc
