SensorPal with EVAL-AD5940BioZ
I'm working on an application where I'll be monitoring the impedance of cells in vitro using custom external electrodes in a 4-wire setup with a target frequency range of 100Hz (or lower) to 100kHz. Initial measurements of the 2000 ohm test resistor in the resistor bank had the attached results
 What parameters in SensorPal can I adjust to improve measurement accuracy?
