Help with AD2S1210
Couple of questions on the AD2S1210
I've assumed the convertor will run in 'default' configuration ..... i.e. I don't need to drive it with a processor to get simple A/B/NM signals out ??
Or does it still need some setup from a processor ??
So I've built a board, supplies are correct (as far as I can tell) but there's no EXE signals coming out.
Again I've assumed the EXE output would run with the power up reset defaults ?
Regards
Kevin
Parents
  • Hi Jgealon,
    Thanks for the reply,
    I have 5V on AVDD & DVDD and 3.3V on Vdrive.
    I've used a 8.192Mhz Xtal and it appears (with a scope) to be running at 8.192Mhz
    I've used the ADM6315 reset circuit and it appears to be high.
    I have no processor connected so have assumed the Excitation Frequency Register is set to the default value.
    I'm just building a test board with this chip alone to see if  I can get it working .... if not I don't know what else to do.
    Thanks for your help,
    Kevin
Reply
  • Hi Jgealon,
    Kevin
Children
