Hi, I try using the AD7856 in Arduino Mega ADK board, I read the datasheet and I have programing under Mode 2, but the AD7856 don't answer me, I connect a oscilloscope to MOSI and MISO lines and Arduino board send correctly the 16bits in MOSI line but in MISO only LOW! so this is my code in Arduino IDE, I hope you can help me!
#include <SPI.h> uint8_t adcMSB = 0, adcLSB = 0; unsigned int read_adc; void setup() { SPI.begin(); SPI.setClockDivider(SPI_CLOCK_DIV4); //master clock 4MHZ SPI.setDataMode(SPI_MODE3); //mode SPI 3 SPI.setBitOrder(MSBFIRST); pinMode(53,OUTPUT); digitalWrite(53,HIGH); pinMode(46,OUTPUT); digitalWrite(46,HIGH); Serial.begin(9600); } void loop() { digitalWrite(46,LOW); //this start the conversion in specific pin CONVST delay(1); //wait the device busy pin digitalWrite(46,HIGH); //and start the trans. digitalWrite(53,LOW); //enable device adcMSB=SPI.transfer(0b11100001); //here I configure the bits in Control Register, read channel 1, power mode normal adcLSB=SPI.transfer(0b00010001); //this read from ADC OUTPUT DATA REGISTER, start the Conversion, select mode 2 digitalWrite(53,HIGH); //disable device delay(300); //read for results read_adc= word(adcMSB, adcLSB); Serial.print(read_adc,HEX); Serial.print(" "); Serial.println(read_adc,DEC); }
and this is my schematic:
Thanks for your question. We are looking into this and will get back to you soon.
Karen
Apologies for the delayed response. Please note that this part should be allowed 150 ms after power up to perform its calibration before any reading or writing takes place. Can you provide scope shots of the digital signals for us to take a closer look?
Hi, sorry to don't answering soon but I have many work and I still fight with this ADC. I write this code to drive the ADC:
#include <SPI.h> uint8_t adcMSB = 0, adcLSB = 0; unsigned int read_adc; //uint8_t CtrlRegMSB = B11100001; //uint8_t CtrlRegLSB = B00010001; uint8_t CtrlRegMSB = B11100000; uint8_t CtrlRegLSB = B00010000; float Vin=0; float N=3.05194e-4; void setup() { SPI.begin(); SPI.setClockDivider(SPI_CLOCK_DIV128); SPI.setDataMode(SPI_MODE0); SPI.setBitOrder(MSBFIRST); pinMode(53,OUTPUT); digitalWrite(53,HIGH); pinMode(12,OUTPUT); digitalWrite(12,HIGH); Serial.begin(9600); //delay(500); } void loop() { digitalWrite(12,LOW); delayMicroseconds(1); digitalWrite(12,HIGH); delayMicroseconds(10); digitalWrite(53,LOW); SPI.transfer(CtrlRegMSB); SPI.transfer(CtrlRegLSB); digitalWrite(53,HIGH); delayMicroseconds(10); digitalWrite(53,LOW); adcMSB=SPI.transfer(0x00); adcLSB=SPI.transfer(0x00); digitalWrite(53,HIGH); delay(100); read_adc= word(adcMSB, adcLSB); Vin=N*read_adc; Serial.print(Vin, DEC); // Serial.print("\t"); // Serial.print(comm,BIN); Serial.print("\t"); Serial.println(read_adc,DEC); }
The ADC works one time, one or two seconds, then stops and does not send anything to the master then turns off and turns on the ADC (a kind of reboot), and work again one or two seconds.
The operation is performed with hardware SPI, SPI previously had with software and the device did not stop and I require that the ADC works with hardware SPI speed matters.
I use the external clock in the CLKIN (pin 22) and pin to CONVST.
This is answer of ADC when the AN1 is in 5VDC:
thanks a lot, best regards!
El mensaje fue editado por: José Miguel Hernández I edit because add the answer of ADC
I have a new version, in this version I read and write in ADC via SPI hardware:
but i have problems with interfacing, I have waiting 15 ms and repeat the instruction as a minimum twice to read more than two channelss: this is the new version:
#include <Expander32.h> #include <SPI.h> /* Definitions to work all channels */ #define AN1 B11100001 #define AN2 B11110001 #define AN3 B11100101 #define AN4 B11110101 #define AN5 B11101001 #define AN6 B11111001 #define AN7 B11101101 #define AN8 B11111101 Expander32 expander(40, 41); //Enable pins to Expander32SS board //uint8_t adcMSB1 = 0, adcLSB1 = 0; //unsigned int read_adc1; uint8_t RstADCMSB = B01000000; //this command uint8_t RstADCLSB = B00000010; //reset the spi in ADC uint8_t CtrlRegMSB = B11100000; //this command select the chhanel 1 uint8_t CtrlRegLSB = B00010001; //this commans is the same to all channels //uint8_t CtrlRegMSB = B11100001; //uint8_t CtrlRegLSB = B00010001; //uint8_t StatRegMSB = B11100001; //uint8_t StatRegLSB = B10010001; uint16_t AD1=0; uint16_t AD2=0; uint16_t AD3=0; float Vin1=0, Vin2=0, Vin3=0; float N=3.05194e-4; //cte to voltaje convertion 5/((2^14)-1) void setup() { expander.init(); //initialitation of the Expander32SS board SPI.begin(); SPI.setClockDivider(SPI_CLOCK_DIV128); //Spi to 125kHz SPI.setDataMode(SPI_MODE0); //SPI in mode 0 SPI.setBitOrder(MSBFIRST); //send the most significant bit first pinMode(53,OUTPUT); digitalWrite(53,HIGH); //Disable the ADC pinMode(12,OUTPUT); digitalWrite(12,HIGH); //PIN to convst ADC Serial.begin(9600); delay(150); //Wait for ADC auto calibration } void loop() { setChannel(AN1); //What channel read? delayMicroseconds(10); //wait the complete convertion 5us AD1 = readChannel(); //read the ADC value // delayMicroseconds(100); // setChannel(AN2); //What channel read? delayMicroseconds(10); //wait the complete convertion AD2 = readChannel(); //read the ADC value Vin1=N*AD1; //Voltaje convertion Vin2=N*AD2; //Voltaje convertion /*Print the results in serial RS232*/ Serial.print(Vin1, DEC); Serial.print("\t"); Serial.print(AD1,DEC); Serial.print("\t"); Serial.print(Vin2,DEC); Serial.print("\t"); Serial.println(AD2,DEC); } /* Method to select the channel of ADC */ void setChannel(uint8_t channel){ for (int i=1; i>=0; i--){ // this methos call twice and dont kwon why digitalWrite(12,LOW); //start convertion delayMicroseconds(1); // digitalWrite(12,HIGH); // delayMicroseconds(10); //Wait a moment expander.Spin(16); //Enable of SPin 16 in Expander32SS board digitalWrite(53,LOW); //Enable ADC SPI.transfer(channel); //channel to set SPI.transfer(CtrlRegLSB); //Same command all channels digitalWrite(53,HIGH); //Disable ADC expander.disable(); delay(15); //Wait 15 ms and dont kwon why } } /* Method to read the value of ADC */ uint16_t readChannel(void){ uint16_t out=0; uint8_t adcMSB=0; uint8_t adcLSB=0; for (int i=1; i>=0; i--){ // this methos call twice and dont kwon why digitalWrite(12,LOW); //start convertion delayMicroseconds(1); // digitalWrite(12,HIGH); // delayMicroseconds(10); //Wait a moment expander.Spin(16); //Enable of SPin 16 in Expander32SS board digitalWrite(53,LOW); //Enable ADC adcMSB=SPI.transfer(0x00); //send 0x00 to generate clock signal adcLSB=SPI.transfer(0x00); //send 0x00 to generate clock signal digitalWrite(53,HIGH); //Disable ADC expander.disable(); delay(15); //Wait 15 ms and dont kwon why } out= word(adcMSB, adcLSB); return out; }
With this code the ADC don't stops but and I write to zero un bus spi to read the sample.
best regards!
Let me check on this. Meanwhile, if you could provide scope shots of the digital signals (/SYNC, SCLK, DOUT, DIN) together in one cycle, it would help a lot.
