AD7712 - measurement error
I am using an AD7712 in a load cell application and am having difficulty obtaining a high level of accuracy across the entire input range of the converter.  My test method utilizes a precision full-bridge with setpoints at 0,0.5,1,1.5,2,2.5,3mV/V and across select gain settings of the amplifier (1,2,4,8,16,32,64) at a notch filter frequency of 10Hz.  The sense method utilizes a kelvin connection at the bridge.  At each combination of points, I average 32 readings from the AD7712 and determine the accuracy due to a change in gain and the actual measurement accuracy.
The kelvin measurement is buffered and fed to the reference inputs of the ADC with a Vexcite/2 (Vref-) and Vexcite*3/4 (Vref+).  Vexcite is nominally 10V.
The reference voltage is <0.1% off of what is expected.
The Vref- input appears to be approximately 6.5mV away from the bridge zero input, which should result in a 0.26% offset error.
I currently have a gain accuracy of 0.16% and a measurement accuracy of 1.16% when I use self-calibration.
I have had a slightly improved response when I use calibration method 4 which provided a gain accuracy of 0.09% and a measurement accuracy of 0.95%.
I am running out of ideas on how to improve this measurement accuracy in my application.  Does anyone have any ideas of things to look at to improve the measurement accuracy?
Parents Reply Children
No Data
