resolver to digital question
I'm researching low cost solutions for resolver to digital. I'm rather novice to electronic engineering though. I've read through quit a bit of the available documentation on the subject.
Main issue is that the resolvers I use are all coming from aviation devices. These expect an excitation of 13v/26v/114v 400HZ.
I've seen there's RDCs like ad2s80 which are rather pricey compared to ad2s1210. So I'm generally searching for a possibilty to use ad2s1210 with 400 hz excitation or some ic in a simmilar price range.
So my question is if someone has a possible solution for using an ic like ad2s1210 with 400 hz resolvers ?
Thank you and Regards,
Gerhard
