Problem with AD7612 on our custom board
We have done our own customized board (PCB) having AD7612 ADCs, having FPGA and other digital components.
We had the idea of making the AD7612 to work in MASTER (SERIAL) mode.
Please find the schematic pdf attached.
We have done the interconnections for MASTER (SERIAL) mode looking into the data sheet of AD7612.
But, we are not getting any outputs from SDCLK or SDOUT or BUSY signals.
We have tested the voltage levels at different power pins (using multimeter) and observed the voltage levels at different power pins are fine.
Kindly look into the schematics and let us know the issue at the earliest.
The different connections that have been made are as follows:
Pin 1: AGND: GND
Pin 2: AVDD : +5V
Pin 3: AGND : GND
Pin 4: BYTESWAP : GND
Pin 5: OB_2CBAR : +3.3V
Pin 6: WARP  : GND
Pin 7: IMPULSE : +3.3V
Pin 8: SER_PARBAR : +3.3V  (SERIAL MODE SETTING)
Pin 9: D0: Unconnected
Pin 10: D1 : Unconnected
Pin 11: D2_DIVSCLK : Unconnected
Pin 12: D3_DIVSCLK : Unconnected
Pin 13: D4_EXT_INTBAR: GND  (MASTER MODE)
Pin 14 : D5_INVSYNC : GND
Pin 15 : D6_INVSCLK : GND
Pin 16 : D7_RDC_SDIN : GND
Pin 17 : OGND : GND
Pin 18 : OVDD : +3.3V
Pin 19 : DVDD : +5 V
Pin 20 : DGND : GND
Pin 21 : D8_SDOUT : SDOUT connected to FPGA device
Pin 22 : D9_SDCLK : SDCLK connected to FPGA device
Pin 23 : D10_SYNC : SYNC connected to FPGA device
Pin 24 : D11_RDERROR : RDERROR connected to FPGA device
Pin 25 : D12_HW_SWBAR: +3.3 V (Since i am making ADC configuration on board by providing inputs to different configuration pins)
Pin 26 : D13_SCIN : GND
Pin 27 : D14_SCCLK : GND
Pin 28  :D15_SCCSBAR : GND
Pin 29 : BUSY : BUSY connected to FPGA device
Pin 30 : TEN : +3.3V
Pin 31 : RDBAR : GND
Pin 32 : CSBAR : GND
Pin 33 : RESET : Connected to Push button switch
Pin 34 : PD : GND
Pin 35 : CNVSTBAR : GND
Pin 36 : BIPOLAR : +3.3V
Pin 37 : REF : Connected to GND via 47uF capacitor
Pin 38 : REFGND: GND
Pin 39 : IN- : GND
Pin 40 : VCC : +12V DC
Pin 41 : VEE : -12V DC
Pin 42 : AGND: GND
Pin 43 : IN+ : Connected to OPAMP
Pin 44 : AVDD: +5V DC
Pin 45 : Temp : Unconnected
Pin 46 : REFBUFIN : Connected to GND via 100nF capacitor
Pin 47 : PDREF : GND
Pin 48 : PDBUF : GND
SCHEMATIC1-PAGE1.pdf
Parents Reply Children
No Data
