Internal calibration of AD7731
I have read through the datasheet and, I am not sure if the AD7731 should be disconnected from the analog signal when performing internal zero scale and internal full scale calibration.
For example, channels 5 and 6 in full differential mode, AIN- driven with a 2.5v voltage source (LM4140) and AIN+ driven from a custom sensor through an OpAmp. REF_in- is tied to ground and REF_IN+ is 5v
Should I disconnect the 2.5v and the sensor OpAmp from the device for calibration?
Should I disconnect only the sensor OpAmp?
Should I not disconnect anything for calibration?
Thanks for your input.
    on Feb 16, 2016 10:48 PM
    Hi Levon,
    It is alright not to disconnect anything during calibration as long as the signals connected to the analog input pins of the device are within the specified limits and noise/interference free.
    RC
    on Aug 2, 2018 3:22 PM
    Thank you,
    EZ Admin
