The datasheet specifies a maximum conversion rate of 200 kHz (5 µs) for the ad7927 converter although the conversion time is as low as 800 ns with a serial clock of 20 MHz.
What happens if the converter is operated with a faster conversion rate? Will there be crosstalk between the inputs, degraded accuracy, or will the device simply blow up :-) ?
