AD7768 DaisyChain Timing
I am evaluating the AD7768-4 for an application with multiple, distributed channels using the daisy-chain mode.
There is some confusing info in the Datasheet on how to calculate the Maximum DCLK frequency:
where t8 = 1/(DCLK/2) , so this formula folds back on itself and seems unsolvable.
Is there an example calculation that shows how to use the formula?
In my case I can calculate the minimum frequency for 10kHz sampling rate with 40 channels using two DOUTx as
DCLKMIN = Output Data Rate × Channels per DOUTx × 32 bits = 6.4MHz
but I am stuck at calculating the maximum allowed frequency for daisy chained devices to check if the AD7768 is feasible for my application.
Parents
    on Dec 21, 2016 7:24 PM
    The formula in the datasheet is incorrect. The correct formula is:
    where:
    FMAX is the maximum usable frequency.
    T11 and T4 are the AD7768/AD7768-4 timing specifications (see Table 3 and Table 5 of the datasheet).
    TP is the maximum propagation delay of the data between successive AD7768/AD7768-4 devices in chain.
    TSKEW is the maximum skew in the MCLK signal seen by any pair of AD7768/AD7768-4 devices in the chain.
    The datasheet revision is ongoing and this will be corrected.
    Jellenie
Reply
    where:
    Jellenie
Children
No Data
