How much is the internal delay when I input a pulse?
I think that a delay produces 30ns in an ISO part.
How many will the quantity of delay in the ADC circuit part be?
AD7400A
Production
The AD7400A is a second-order, S-? modulator that converts an analog input signal into a high speed, 1-bit data stream with on-chip digital isolation based...
Datasheet
AD7400A on Analog.com
Hi ,
We are looking into this and get back to you.
Jonathan
Hi oti,
I am confirming some data with the product line. I'll get back to you.
Jonathan
Hi oti,
The AD7400A is Sigma Delta modulator. The clock is internally generated and will drive the modulator. Then both clock and modulator MDAT signal are transferred across the isolation and appear at the microcontroller at the same time. The delay to cross this is very minimal. The AD7400A is a Sigma Delta modulator and requires filter which will add majority of the delay.
Jonathan
