AD7606-4 REGCAP Pins
What would be the consequence of not connecting the AD7606-4 REGCAP pins (36 and 39). Would the conversion results not be accurate, or would the IC stop working all together?
Parents
    There will be a degradation in the conversion results. This has been confirmed on the AD7606-4 evaluation board under nominal conditions and at a temperature of 25C. Not having the correct decoupling may cause the regulator to ring or oscillate. There may also be conditions where the AD7606-4 stops functioning altogether, for example under certain supply conditions or at temperature.
    All of our characterization has been carried out with the decoupling capacitors in place. As a result we cannot guarantee the device will continue to operate under all conditions.
    Regards
    Niall
Reply
    Regards
    Niall
Children
No Data
